Just throwing this video out there, points are all very true. Explains why today’s extended maintenance intervals are a farce
Depends on the year. On the 2018 Expedition the recommended change is 150,000 miles for transmission, differentials, and transfer case. For coolant it is 100,000 miles initially. Then the manual says every three years or 5,000 miles for coolant. I believe the 5,000 miles is a typo(maybe Chinese translation?) in the manual and should be 50,000 miles.
I have seen his videos before and actually agree with them, I am just quoting the manual based on Trainmasters last sentence. I have a 2006 F350 DRW 2WD. Gets the trans fluid replaced every 30k and the coolant, trans filters, and diff fluid every 60K. I haven't decided yet, but the trans and diff will get serviced at either 50 or 60k. I do not believe in forever fluids.I get the feeling you didn’t watch the video because he tells you and shows you exactly why ford and the manual are wrong. The 2018 Expy is no different from any other ford vehicle.
