2010 2wd Expedition has started having issues shifting out of park. The first time I turned it off then back on and it recovered first time. Now, thats not always the case and it's happening more frequently. I've done some reading but trying to narrow it down to what it is (brake lamp indicator, brake shift interlock actuator, fuse, etc).
When it happens, the button on the gear shifter (center console shifter) will not depress but I hear the click in the dash. The brake lights do NOT illuminate when this is happening either. I can keep fiddling with it and sometimes press the brake down really hard and it will recover and go into gear. It moves through the other gears fine after this and the shifter does not feel loose.
Hoping to narrow down the issue so I don't throw money at the wrong issue. Thanks in advance.
