I replaced my A/C about a month ago. Before you begin take off the air intake and all that jazz and take off that plastic shroud that is on top of the radiator where the hood latch is. Then I unbolted and removed the fuse box, power steering reservoir, vacuum reservoir. Next I went under the truck and flipped the bottom portion of the fan shroud up and removed the fan blade....then it’s shroud removal time. There are a few bolts hidden toward the front holding the fan shroud in place remove those and then the fan shroud..... Then take the three bolts out of the compressor and move it forward and you can now easily access the lines on top leaning over the front. The filter drier is a sock up in the right side of the condenser if you remove the rubber matting from underneath you will see where the little plastic cap is.
