SEPTIC PROFESSOR
I need to locate and test the relay (not the fuse) that turns on the washer motor for spraying the windshield. Thanks in advance !
Septic Professor, maybe you can help me. The button on the end of the blinker (turn indicator) arm that should activate the washer pump for the front windshield does not activate the washer pump. The rear wiper washer works fine. There is only one pump, correct?Thanks, emphasis noted and appreciated ! Many Expedition washer pumps are needlessly replaced due to a weak/worn front actuator relay. They either work in both directions or they don't. A weak/worn washer relay often requires engine running charging voltage to actuate per my extensive testing.
In almost every instance, the washer motor rear operating strategy works flawlessly for the simple reason
its relay is seldom actuated.
That is my exact symptom. Are you saying I need to replace the fron wiper motor?
