Wheel Noise
Tonka
Columbus,Ohio
I have a 2013 Expy, I have a grinding feel coming from drivers front when turning (not all the time though). Before the grinding feeling and noise was from the wheel bearings got those fixed and a tie rod. What could still be making the grinding feel???
71Rcode
DFW Texas
Hey check out my posts from the past year. I replaced the IWEs and the wheel hubs/bearings....solved my problem
99WhiteC5Coupe
You could have a worn brake pad that is causing the grinding, or a slightly bent rotor splash shield that is rubbing on the wheel or something else when you turn.
Since you had some wheel bearing work done, it is possible the mechanic bent the splash shield. You can look for shiny “witness” marks on the splash shield to see if something has been rubbing on it.
Doug Reed
Woodruff, WI
I just had a rear wheel bearing assy and a front caliper that was hanging up replaced.....good news - total silence...bad news-$900 previously known as $500 repair bill. (I DON'T wrench myself).....
JasonH
Houston, TX
Never too late to start!
SPLASHMIT
KSA
I had the same experience 2 months back. I replace the wheel hub and was not totally gone. The main problem is the 4wd locking hub actuator which is causing the grinding feeling. I replace this locking actuator and noise were gone.
mlself
