Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Sponsored Ads
Register to remove these ads.
General Discussion
Windshield washer fluid will not wash.
This is a discussion on Windshield washer fluid will not wash. within the General Discussion forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! My windshield washer fluid will not dispence. I checked the fuse, replaced the ...
Reply
Old 12-17-2006, 05:01 PM   #1 (permalink)
Registered User
Unhappy Windshield washer fluid will not wash.
My windshield washer fluid will not dispence. I checked the fuse, replaced the pump. I don't know what to do next. Any help would e great.
Thanks.
lifejacket is offline   Reply With Quote
Old 12-17-2006, 11:33 PM   #2 (permalink)
Registered User
Default
My 98Eb was doing the same thing and I found that the passenger side floor board was getting wet. I looked around behind the plastic trim molding on the passenger floor and found that the hose had come uplugged...it connects here to run back to the back window washer. This was causing the whole problem. Every time I turned on the washer fluid it was emptying on the floorboard. Hope that helps!
wstuler is offline   Reply With Quote
Old 12-18-2006, 11:52 AM   #3 (permalink)
ELVATO's Avatar
Super Mod
Default
Maybe the "squirters" are plugged? A needle might help.
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 12-18-2006, 01:29 PM   #4 (permalink)
Default
Last year I had a similar problem on the center sprayer on my 03 xp. It turned out the sprayer had clogged up. I took a very small needle and cleaned out the jet. I has worked good since. Another problem could be the outside temperature. If it gets cold enough sometimes they'll freeze. You can buy a washer additive, its kind of like anti-freeze for windshield washer fluid. The fluid is also sold with the additive already in it. The brand I use is called purple power. Hope that helps
toocivil is offline   Reply With Quote
Old 12-18-2006, 06:19 PM   #5 (permalink)
Registered User
Default
I can not even hear the pump turning when ingaged.
Old 12-22-2006, 01:37 PM   #6 (permalink)
Default
I guess have some one activate the pump for you while you are near the pump in the engine compartment. If you cant hear it or feel it run, it could be shot since you said you already checked the fuses. It could be something as simple as a short in a wire also. Check all the hoses to make sure they are connected. If that doesn't do it, it may be time to take it to your Ford dealer.
Old 12-23-2006, 12:42 AM   #7 (permalink)
Registered User
Default
I replaced the pump with a new one still no go.
Old 12-31-2006, 07:56 PM   #8 (permalink)
Registered User
Default
I bought a rear wiper motor to replace the one that is not working. I started to unbolt the motor and noticed a plug dangling I looked around the motor saw a empty port pluged it in and the wiper went to home. I shut the back lid and turned on the rear wiper worked fine, tried the washer fluid for kicks and again woked fine for front & rear. I thought that maybe I should replace the current one with the one I bought from salvage out of a 2006. After inspection of the current motor it looked new. The wiper motor & washer fluid did not work the day I bought the suv. I figured the mechanic that replaced the motor never pluged it in. I am still going to hang onto the motor for a while.
The moral of the story:
If your washer fluid & rear wiper motor is not working good chance it's not plugged in.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
