Tocapet
I will check out those other fuses. Breaker #47 checks out with an ohm meter.
Glass and regulator operate smoothly. It was working up until the regulator cables got frayed and jammed the pulleys. So I replaced the regulator and used the same motor.
Everything is working, just no auto up/down.
Thanks!! I'll let you know as soon as I can check it out.
