Tocapet
So my driver side power window regulator on my 2009 Expy EL XLT messed up. I purchased and installed an aftermarket regulator from Advance and installed it. Everything works fine now except for the auto up/down feature. I have tried multiple times to do the de-initialization/initialization procedure 501-11-1 (ign 5 times, down 2 sec, up 2 sec) and it stays the same. I have tried the earlier model procedure, (down button 6 times) and no help. I have tried disconnecting the battery while the glass was moving, still no difference. All fuses are good. (F1, F41 and there is no F47) I know if I call the dealer, he is gonna say I need an OEM regulator, but that can't be because there are no sensors or any connections that have to do with the windows on the regulator. Although the regulator is aftermarket, it was identical to the OEM. So here I am patiently holding down the button whenever I need to lower or raise the glass. The auto was working before the regulator messed up. So I'm appealing to you guys who may have been through the same problem. Any help will be greatly appreciated. I apologize for starting a new thread, but I fear that the other threads are too old for anyone to notice. I need help!!!
