montecarlo31
Google would have all of the proof you need. Higher octane is designed to allow for higher compression motors to run without early detonation. If you increase octane without increasing compression, no more power is made. Stick with 87.
Sent from the Pocket Computer
Not quite but thanks for playing. There is more to the equation then simply "compression" and google. If the engine can make more power on E85, which it does, it WILL make more power on 93, 95 etc. Remember these engines has the ability to adjust timing on the fly which is where the increased power comes from when running E85. There is no change in compression as you imply.
