ok been a while
cabin filter on a 2003 eddie bower, where is it??? Pahleeease tell me I have googled it to death and still can't fine a proper illustration.
Back to the a/c issue, ok I got a clicking noise from the rear a/c last week. Me and my kid (she's 9) pulled the rear panel after ebay'ing a new air mix actuator, low and behold the last owner was so slick he has disconnected the other air switch too, ran to advance changed both actuators, I never knew the air could be changed from overhead to the floor in the rear, oh well age does this to a person.
Ok I thought the front issues had to be the notorious air mix actuator in the dash, boy were we right, I followed the advice here and went through the radio without pulling dash, advance and their switches for the front don't cross ref for 2003 EB,burned up two, before I went to ford and got the OEM (97 bucks).
I also found when it comes to set temp say 71F, it will start blasting heat out, so I have to set to 65, and adjust the fan manually, I have ordered a cabin sensor from Tasca, and will replace it this week. My pressures are 55ls and 235 HS with ambient at 94F. So now I notice the front air seems a little weak, where the heck is the cabin air filter????????????????????????
I am going to search for it but could use a few pointers here. thanks red423
P.S. I tell you what, my dad before he passed worked the line at ford back in the 60's, you can say what you want to, but I have always been partial to fords, especially their trucks. My uncle in Ohio owned a 36' which was a daily driver, and my dad had a 67 F100 as his when he passed. Yes, they have a few issues, and yes they can and do over engineer a lot of things, but when it is all said and done and she is running right, that's my baby, and I know my dad would be proud I own her. red423
