Go Back   Ford Expedition Forum > Ford Expedition Forum > 1st Gen - 1997 - 2002
Register to remove these ads.
Dash won't light up anymore (2000 Exp.)
This is a discussion on Dash won't light up anymore (2000 Exp.) within the 1st Gen - 1997 - 2002 forums, part of the Ford Expedition Forum category!
Earlier this year I lost all my dash lighting. At first it was intermittent, now they just won't come on ...
Reply
Old 10-15-2011, 01:52 AM   #1 (permalink)
Registered User
Default Dash won't light up anymore (2000 Exp.)
Earlier this year I lost all my dash lighting. At first it was intermittent, now they just won't come on at all. It's almost like something is loose though because once in a (very long) while, they will come back on for a few minutes then be gone again.
I also had the problem where the odometer wasn't lighting up consistently anymore either so I thought the two were related.
So, using information from the following threads, I attempted to fix both issues.
Odometer problem:
(Removing the cluster)
http://www.f150online.com/forums/art...r-97-03-a.html
(Fixing the actual problem)
http://www.f150online.com/forums/art...r-99-03-a.html
Dash lights not working:
http://www.f150online.com/forums/lig...t-how-fix.html
Unfortunately for me, the 2000 Expedition cluster doesn't have the parts referenced in this link. The three wires, the fuse, etc. just aren't there.
Does anyone know where these parts are on the 2000 Expedition, or more importantly, how to fix the problem?? I don't mind the darkness at night, but I can never see exactly how fast I'm going!
Any help would be greatly appreciated.
Ryan
__________________
2000 Expedition Eddie Bauer
Medium Wedgewood Blue
Mods:
K&N Filtercharger
Gibson Cat-Back SS exhaust
ryandelany is offline   Reply With Quote
Old 10-15-2011, 09:29 AM   #2 (permalink)
Thermo's Avatar
technical advisor
Default
Ryan, if you lost all of your dash lighting, then odds are you have lost the dimmer control module. That is built into the headlight switch. So, get yourself a new headlight switch, remove the headlight switch and that should fix your problem.
__________________
Official Member of the Lifted Expy Club
Thermo is offline   Reply With Quote
Old 10-15-2011, 01:53 PM   #3 (permalink)
Registered User
Default
Thanks Thermo.
Is there a way to somehow test that before I go buy another one? Is that the part that you spin up/down to dim/brighten the lights? If so, I can spin it all the way up and turn on the overhead lighting in the vehicle. Not sure if that's an indication that the switch is ok or not, but thought I'd mention it.
Also, I've checked fuses, etc. and none of them seem to the be problem. Not to mention that once in a very long while, the lights do work which leads me to believe it can't be a bad fuse.
Ryan
__________________
Mods:
K&N Filtercharger
Old 10-16-2011, 02:04 AM   #4 (permalink)
Thermo's Avatar
technical advisor
Default
Ryan, you will need to pull the headlight switch out and then find a light blue/red wire. Put the red lead on the light blue/red wire and the black lead on chassis ground. Then with the headlight switch not in the OFF position, if you are seeing voltage on this wire, then the problem is the wiring inside the dash. If you don't see any voltage there, it pretty much confirms the dimmer module is toast.
__________________
Old 10-16-2011, 02:35 AM   #5 (permalink)
Registered User
Default
Thermo,
That's great news. I just did what you said and there was no voltage at the switch. In addition to that, I realized that the odometer, stereo LCD, and HVAC LCD (which still work), don't dim when you spin the wheel up and down which further supports your assessment that the dimmer itself is shot.
I'll go ahead and order a new switch and see if that resolves the issue. I'll keep you posted, thanks for the help!
Ryan
__________________
Mods:
K&N Filtercharger
Old 10-23-2011, 02:07 PM   #6 (permalink)
Registered User
Default
Just an update on this thread in case anyone else has the same issue. I ordered a replacement part, Motorcraft SW5980 for $69 from Amazon, got the part yesterday and promptly replaced it. Much to my surprise, it worked and solved the problem with all the dash lights. I had forgotten how many things light up in the truck at night (door lock buttons, steering wheel controls, HVAC controls in the rear, rear window buttons, etc.)
If anyone else has the problem where your odometer, time on the stereo, screen on the HVAC control unit, and the overhead compass work but no other lights work, replace the light switch/dimmer combo. It's really easy to replace yourself (pop out the unit, unplug two wire harnesses).
Thanks again for your help Thermo!
Ryan
__________________
Mods:
K&N Filtercharger
Old 10-24-2011, 07:15 PM   #7 (permalink)
Thermo's Avatar
technical advisor
Default
ryan, not a problem. Once you know how the truck is wired up, a lot of the electrical problems are easy to figure out.
__________________
Old 05-07-2013, 10:40 PM   #8 (permalink)
GilGraue's Avatar
Registered User
Default
Hey guys. I just got a 2002 expy eddie bauer edition a few days ago. I am having the exact same problem with the cluster lighting as well as radio buttons, door panel buttons, etc not lighting. I can turn on and off the interior dome lights and head lights, but nothing at all illuminates at night (except overhead compass). Will replacing my headlight switch fix this issue as it did for you???
GilGraue is offline   Reply With Quote
Old 05-08-2013, 01:24 AM   #9 (permalink)
Registered User
Default
Your symptoms sound exactly like mine, in which case, the answer is yes, I am confident that will solve your problem. Seems like the switch just wears out over time and loses contact, so replacing the whole unit solves the problem. My lights are still working to this day after replacing the unit.
Good luck!
Ryan
__________________
Mods:
K&N Filtercharger
Old 06-29-2013, 10:22 PM   #10 (permalink)
GilGraue's Avatar
Registered User
Default Re: Dash won't light up anymore (2000 Exp.)
I actually replaced the fuse under dash as well as under hood. Both with 25 amp fuses. No issues at all now
Sent from my SGH-T989 using Tapatalk 2
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
