only left half of my dash lights work
nick8102
MN
so I finally got my expy running and it works well for the most part aside from a few minor things the biggest currently is only the left half of my dash lights are working any ideas what this could be?
also my battery light comes on if i turn the headlights on and it will flicker on and off periodically any ideas on this also?
Thanks,
Nick
Maverick1701
Memphis, TX
I have a single behind-dash light that is intermittent (the rest work as they should)...drives me crazy. If I smack the dash it will come on hahahaha
Free bump!
hortonguy
ohio
if only half the lights are out you probably just need to change the bulbs in the cluster not a hard job just did mine in my 98
Lightnig
Behind you
agreed, simply bulbs in dash burnt out from the sounds of it.
And spend the bit of extra money and get a good quailty high output set, and replace all of them, both in the dash and in the heater controls.
Well worth the money
Not too sure about the battery light though. My first guesses without further information would be either a weak battery or a weak alternator. Or maybe regulator...
Your local parts store can test these all (the alternator and regulator should be off the truck for them to test) to pinpoint which, if any, need replacing.
