My bad, the expy is all electronic controls for the HVAC
Does the air flow change at all when you hit the buttons and does your fan speed controls work on all the settings?
If not it may be the blend door or the controller its self not changing the flow.
Normal Operation
Under normal operation, to rotate the mode door actuator clockwise, the electronic manual temperature control (EMTC) module or HVAC module - dual automatic temperature control (DATC) supplies voltage to the FLOOR/DEFROST/PANEL mode door actuator motor through the circuit CH228 (YE/GY), and supplies ground through circuit CH229 (WH/BU). To rotate the mode door actuator counterclockwise, the HVAC module - EMTC or HVAC module - DATC reverses the voltage and ground circuits.
The mode door actuator feedback resistor is supplied a ground from the HVAC module - EMTC or HVAC module - DATC through circuit RH111 (GY/BU) and a 5-volt reference voltage on circuit LH111 (BN/WH). The HVAC module - EMTC or HVAC module - DATC reads the voltage on the mode door actuator feedback circuit VH436 (YE/VT) to determine the mode door actuator position by the position of the actuator feedback resistor wiper arm.
DTC B1003 Mode Door Short/Failure - The module senses no change in actuator feedback voltage when the actuator motor has been energized.
