Drivers door
Beni1888
Long Island, New York
Ok so well when i shut my driver side door it locks it self and i have too put my door pin in to unlock the door does anyone now what it might be or a fix
stamp11127
Temple, Georgia
Autolock (if equipped)
This feature automatically locks all vehicle doors when:
• all doors, liftgate and liftgate window are closed
• the engine is running
• you shift into any gear putting the vehicle in motion.
Relock
The autolock feature repeats when:
• any door, except the drivers, is opened then closed while the engine is
running and
• you put the vehicle in motion.
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors and the liftgate window are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Beni1888
Beni1888
Ok well i just did the sequence and guess what still happens when i close the door sometimes ill close it once and it will open and close it thentry to open and its locked
