Go Back   Ford Expedition Forum > Ford Expedition Forum > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
How to install Signal Mirrors
This is a discussion on How to install Signal Mirrors within the Tech Info forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! This installation is for 2003-06 Expedition XLT. You can use the Eddie Bauer, ...
Reply
Old 03-23-2011, 06:26 PM   #1 (permalink)
Default How to install Signal Mirrors
This installation is for 2003-06 Expedition XLT. You can use the Eddie Bauer, Limited, King Ranch signal mirrors or the 2003-06 Navigator mirrors. First lets disconnect the battery. Pop up the window control module.
Materials Needed:
1. 2-3 ft of wire (14 awg) colors doesn’t matter.
2. 4 butt connector
3. Left and Right Signal mirror
Tools Needed:
1. Crimpler
2. Wire Stripper
3. Flat tip screwdriver
4. Torx (T-20)
5. Ratchet
6. 7mm socket
7. 13mm socket
Pop up the door sill.
This is how it look after it is remove.
Grab and pull out the weatherstripping like in the photo, it is not glue in.
Pull the Hush panel forward to release it.
This is why you pull the Hush panel forward because of the tabs
Put a Butt Connector on the green wire with white stripe, run a wire about a foot and half from there into door boot and up to the mirror connector.
See black Tab in front of the green connector, the Hush panel must slide over this when you replace the Hush panel.
This is the channel in the floor if you need to run wires to the back ie, subwoofer wires.
This the boot that the wire will come through, don't worry about the ground because the plug has the ground already.
Push up on the door panel switch to release it.
Now lets remove the door panel, oh, by the way my mirrors has been install over 7 years, I took the door apart to make sure I'm posting the right info. There are 2 bolts (7mm) at the bottom and 2 torx screws (T-20) behind this tab.
Unplug the window switch module and sat aside.
Make sure the door button is in the lock position, then pull up on the door slightly moving it back and forth or up and down it will come off look at the pictures to get an idea where the tabs are so you don't break them or the lip off.
Don't forget to unplug the mirror on the door panel. Now would be a great time to upgrade the front speakers if you like, they are 6x8's I purchase these at Walmart for around $50. and they fit ford products.
Remove the stick-on that covering the mirrors bolts, there are 3 bolts(13mm).
This step go ahead and pull the stick-on for the large door panel back enough to unplug the the mirror connection and remove the mirror from the door and replace with the signal mirror that you have purchased, run the mirror harness through just like the old one. The wire that you tap into (green wire with white stripe) will butt connect to the green wire with white stripe on the signal mirror plug that you just install.
Now is the time to test it by connecting the battery and turn on the turn signal for the left side, the puddle light and the turn signal should be working now. If not check the connection. If it is working disconnect the battery and reassemble the door and get ready to do the passenger side.
On the passenger side you don't have to remove the Hush panel, the weatherstrip or the door sill. Go ahead and remove the door panel, the old mirror and install the new mirror and route the harness but don't make any connection because on this side the wire is a different color. Open and empty the glovebox there on both sides near the rear push in on the tabs and the glove will drop down out of the way and you should see this, this is where I have the wire tap. The wire is white with a blue stripe.
corvettej is offline   Reply With Quote
Old 03-24-2011, 12:37 PM   #2 (permalink)
Sierra Lima1470's Avatar
Default
Thats a great write up! SOO many steps for a mirror. Good pictures. I dont need to install mirrors BUT I do need to remove my door panel to fix my window track. and this showed me how! Thank you!
__________________
[url=http://www.flickr.com/photos/66406882@N02/6059287851/]
Gotts mod, K&N air filter, Flowmaster 40 Series Delta Flow
Sierra Lima1470 is offline   Reply With Quote
Old 11-30-2011, 06:39 PM   #3 (permalink)
Default
Great Writ-up. Just got my mirrors. Looks like my Saturday Project.
__________________
2003 5.4 XLT 4x4 w/Tow Package, 5K Hids, Gotts Mod & KN Filter, Coilover Conversion, Tint, Prodigy Brake Controller
Blwnl36 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
