2007 expedition - changed all the plugs with HT1 platinum and also changed the coil on cylinder 6 - i looked up that cyl 6 was the 2nd one from front of engine on driver side
pass driver
firewall
4 8
3 7
2 6 ****
1 5
grille of front
took off the fuel rail on driver side and did a professional cleaning of the injectors
1. with injectors off completely - filled each with seafoam
2 hooked battery charger to + and - nodes of the injector
3 at the same time used compressed air and made it all blow thru
yes you can use this idea as it works to really clean an injector
just bump the + on the battery charger to get it to open close open close
---- With all that said it still throws code that cyl 6 is misfiring
i also took a test light to the plug and it is pulsing a light off of 6
help - i need to get this inspected soon and it wont pass like this.
pass driver
firewall
4 8
3 7
2 6 ****
1 5
grille of front
