LED turn signal hyperflash
mh68
Missouri
Ok so I replaced the taillights in my 2011 limited and have the led hyper flash. I bought a led turn signal module to fix it and I can't find the location of it anywhere. Does anyone know where it is on a 2011 or is this something that will have to be changed in the programming?
Limited EL
Latham, NY
On my 2010, I changed out with V-Leda in the tails, but my front directional I used Morimoto Switchbacks and bought a 3157 harness pigtail with resistors added to it. And this corrected my hyper flash. I couldn't locate a relay to change myself, which is why I went the rough time I did.
M
mh68
Missouri
Myou 2011 doesn't have one so I'm going to end up having the bcm reprogrammed to eliminate the hyperflash.
sharprd65
