My first Ford Expedition.
Yupster Dog
Super Moderator
Super Moderator
It is super easy to get out and put back. not hard at all and you get your odometer/ trip back for good.
I had to because i use my trip for every tank of gas to monitor my MPG
backnine29
Pacific Northwest
Watching the video had me envisioning a struggling, 6 hour project just to get the dash off- OR getting the dash out without much problem then taking 6 hours to get in back in. I would need to set aside a full day for the project given my low confidence level over it. Pretty apparent that I am not mechanically inclined. [emoji37]
Sent from my SAMSUNG-SM-G930A using Tapatalk
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
I’m telling ya I got an anxiety attack watching that dude pull apart all those panels.
Wonder what my Indy would charge?
I need my trip odometer daily.
backnine29
Pacific Northwest
I was given an estimate of $740 by my local mechanic to fix it. Dealer probably $1500!!
JamaicaJoe
Oviedo FL
I have put off fixing mine, keeping a mileage log whenever it blinks on. There are about 24 screws to remove, 17 on the dash, another 7 in the cluster. The fix is simple enough. Do remove the old solder with a solder wick before globbing on a bunch of solder. There are a couple videos on line explaining this. Don't screw up the shift indicator cable.
After I fix my driver side power window, the ODO is next on the list.
brhulen
Olympia, WA
Our 1997 XLT with the 4.6 has a little over 187k on the clock. Have replaced the GEM module twice and getting ready now to replace it along with the fuse block for the third and last time! The dealership initially told me it was the leaky windshield so replaced that and the first GEM and it still leaked. So took it back in and they told me the new windshield was also leaking and no way to reseal. So a second new windshield was installed and lo and behold they then discovered it was the body molding leaking and not the windshield. Did I mention that the i had to put in another GEM module? The vehicle sat for a few months and when I went out to start it it exhibited all the signs and symptoms of a bad GEM again. So this time I'm determined to replace the GEM and fuse panel myself and see if there is some other way to keep water from getting in there. Otherwise it's been a good rig and otherwise bullet proof reliable. Regarding the transmission flush, I've always heard it's better to simply drain and install new filter and gasket as sometimes flushing on a high mileage unit can dislodge sludge particles that don't get flushed out and may get lodged in passageways in the tranny
Machete
Illinois
Re the tranny flush. It’s probably not a good idea if you have high miles and never done it before.
My truck has had it since 50k so it never got sludge to begin with. Shifts so smooth you can hardly feel it.
Bilsto
Nashville TN
Good God. They must be quoting replacement of the whole kit n' caboodle. I wish I could help.
