wakeboarder
huh - odd, my cpo ‘19 doesn’t have DRL at all - i just assumed the halogen rigs did not have, and i don’t seem to find any menus settings anywhere. does that mean it was turned off on forscan by previous owner? either way - i guess i won’t have to worry about that -
as far as the inrush voltage - you mean the traditional HID power draw “spike” at lighting startup? i wondered the same thing also - whether the ballasts smooth that out in terms of actual startup power draw -
DRL’s are hard to check for since you have to be in drive. The USA versions have an option to enable or disable DRL under advanced options>lighting on the instrument cluster.
Yes, the inrush I described is what you are referring to as a spike.
