Carl Keef Jr
When I am coming to a stop, it's like the transmission is late to get the notice to downshift and roughly comes to a stop. Same thing when I start driving again. I give it gas and it sits there for a second or two and then it's like it slams into gear. Today, I took my foot off the brake after coming to a stop, gave it some gas to make a turn onto a highway frontage road, and it started rolling backwards a bit before it slammed into drive and took off. It nearly made me hit the car that was behind me. Occasionally, it will get really bad and I will pull over, turn off the engine, start back up, and then it will be fine. I have done the adaptive transmission learning reset mentioned here: Ford Quick Tips #66: Harsh Shifting Transmission Fix https://www.youtube.com/watch?v=jWMliD_3s3o. I recently had the transmission fluid and filter replaced and they said everything looked good. I have also changed the differential fluid. Any ideas on what is causing the issue? Thanks in advance for your help. 2010 Ford Expedition Limited 5.4 3v 160,000 miles
