Gorilla Lug Nuts Fit
zak99b5
zak99b5
Albany N.Y.
Received said set of lug nuts yesterday, and they look basically identical to the Ford ones, sans the problematic trim cap of course.
GixxerJasen
DFW TX
On Amazon I found Zoffi black forged one-piece lug nuts. They claim to fit my vehicle (large acorn seat), and have a diagram with the proper measurements (incuding the proper 21mm hex size), and they were $43 for 24.
Have you gotten them installed yet? Any pictures?
RacerBX1
SE Michigan
If anyone is looking for a lug nut set from Gorilla with all the nuts being locks and in black with 24 nuts the below part number is it. They are the correct taper and size. I installed them last night and everything was perfect. My Expedition is only a month old and some of the factory lug nuts were already starting to swell where I had to tap them out of the socket after removal because I could not pull them out. Probably around 4 to 6 of them needed to be tapped out.
96644BDX​
bigwilly
96644BDX​
Wow. My Expedition is about a month old too. I just received the Gorilla set I ordered today. I was planning on waiting a bit before replacing but I guess I'm doing it this weekend.
zak99b5
zak99b5
Albany N.Y.
It’s easy. I didn’t lift the truck or anything. Just unscrewed two opposite lug nuts, replaced with the new ones, and torqued to spec. Repeat 12 times.
8131full
Las Vegas
Can't recommend the need for everyone to swap the stock lugs out ASAP. I used these: https://www.amazon.com/dp/B089RG7XJH?psc=1&ref=ppx_yo2ov_dt_b_product_details
If you ever think you might get a flat after someone else has rotated your tires etc, don't expect to be able to get the stock lugs off on the side of the road. Those things are junk. Even just holding both of these in your hand you can tell the difference. Much heavier and solid.
expresspedition
