Cruise Control at Stop Taking Off - Dangerous
mwar99
NJ
If you read the original post you would see that he can easily hit that big button by accident.
But again, why? I have not accidently hit any button on the steering wheel. How big are his hands? I just don’t see how you accidently hit that button while in a drive thru.
SyndicateZ
Mass
Operator error/unresponsible driving habits is what this boils down to.
rd618
new york
I do see it’s intended to set the speed to 15 mph if you are at a stop and there is a car in front of you.
As a software engineer, allowing you to do this while you are obviously not on a road with one button press is absolutely bonkers. Its intention is for stop and go traffic. They are already differentiating between parking lots and roads with the smart speed thing. I don’t understand why they would allow that in a high pedestrian area.
I don’t however see how you can disable that one function, the stop and go part.
you cannot yet disable just the stop/go part of the assisted cruse control. If you disable the distance following element, it will default to standard cruse functionality, which means hitting that button will simply cycle the "cruse on/off" it will not then set a speed.
The system is working as intended though, so it's not technically a design flaw. It would be incredibly difficult to differentiate between someone pulling off to the drive through right next to a road or on a side road or parking lot, and being on a road with stop and go traffic.
My advice is if you find yourself hitting the button that often, disable the distance following. or use extra caution before taking your foot off the break if you really need the feature.
mdecillis
Iselin, NJ
But again, why? I have not accidently hit any button on the terming wheel. How big are his hands? I just don’t see how you accidently hit that button while in a drive thru.
I can see it happening. Especially if you're wearing a big bulky jacket, that button is very easy to push and it's bigger than the others closest to where you hold the steering wheel. Accidents happen.
K
KetMalice
Oklahoma
Just kind of an FYI. I did more testing. It’s not actually working correctly. You can even see it in the video.
When you are stopped with your foot on the brake for like 5 seconds, it’s supposed to disable the cruise control. You can see in the video, it recognizes it’s stopped, and then says hit the resume button to activate cruise control. I did not do that and the expedition took off on me.
I mean, the argument that someone has never hit a button on accident is a terrible argument. I mean people handing you things through a window, turning with gloves/coats on, kids screaming behind you. I mean if 50k of these expeditions are on the road for 10 years, just out of sheer numbers that button is going to get hit under those circumstances a lot.
Again what it is supposed to do in those circumstances is set itself, if it detects you are at a stop for X seconds it disables cruise and requires you to hit resume. This is not happening. I don’t know if it has to do with speed recognition or the lack of auto start stop on my expedition. But it’s dangerous.
rd618
new york
I tried it on mine this past weekend. I still cannot replicate your specific situation. If it doesn’t detect a speed sign it will default to 15. If it does it defaults to that speed. As soon as I lift off break if it was less than 10 seconds or so. It does start to inch forward. Not a full throttle situation by any means.
If it detects a car or person (assuming person, in my case it wouldn’t drive forward into my forsythia) it will not move.
The truck doesn’t move after it’s stopped for a solid 7-10 seconds (I was at a light). I either have to press the gas or hit resume.
Not arguing with the button being big or ease of hitting it. But it’s just not happening to me and definitely not a situation I’ve run into that causes concern in the past 8 months.
CDNRabbit
Ontario Canada
And I was just starting to be productive today... now I need to go play with the truck for 20min
Seriously though, I hit the steering wheel buttons all the time when making big turns causing either a warning in the cluster or changing the display. They are sensitive and I could see someone grazing the cruise on button now and again.
CDNRabbit
Ontario Canada
I remember to try to set the cruise in traffic today Pressing the cruise ON sets it to 20kmh when stopped behind a car. When I release the brake it brings up the message "stopped" and then auto holds the brakes (I don't have auto hold turned on). When the car in front starts to move it shows the resume button symbol. It won't start to role on its own.
SyndicateZ
Mass
If your vehicle tries to accelerate while in cruise control with a vehicle in front of it the module is deemed compromised.
Staff online
Wolf_Lazarus
