Catch Can!
chuck s
Can't hurt. My 30,000 mile 2017 showed a check engine light last Spring that my basic OBD2 reader indicated was a bad catalytic converter. Back ordered at the dealer and resetting the light just made it re-appear until I did the infamous Italian tune-up and it stayed off. I'd never hammered this SUV that hard and the acceleration rate was impressive and almost scary. :) Cat has been replaced (still under emissions warranty) and no CELs since.
Weather is nice today so I guess I should empty my catch can. I put the extension on the bottom although it's never super full.
-- Chuck
Super Moderator
Super Moderator
Read about 3 pages right from the beginning and ordered a J&L separator for my '17 Expy which I purchased a few weeks ago (84k mi). Does the ol Italian tune-up work with this engine though? Figured I should do whatever I can to get as much longevity out of this vehicle as I can. Also have a set of Ruthenium plugs ready to install too.
Yes, a hard run regularly does help! Never an issue with any vehicle I own!
As far as the plugs, what part number did you get? Also, the gap is VERY important.
OneTonWonton
Grand Forks, ND
Thanks for the confirmation (and all your other tips and suggestions across this forum).
90495. I saw your post elsewhere to get one step colder but I just went with the one RockAuto had listed. Will make sure to gap properly.
Super Moderator
Super Moderator
Welcome!
Atleast you got the right gapped one! They should be .031 out of the box, and as long as you aren't planning on tuning, that gap should work good. Yes, they are heat range 6. The ones I recommend are 95605, which are heat range 7(1 step cooler), but what you ordered will work fine.
OneTonWonton
Grand Forks, ND
Welcome!
No, I have no intentions of tuning. It's already got enough engine performance for my needs. More interested in maintenance and reliability tips. If anything, I may consider beefing up my brakes and suspension but I'll cross that bridge when it's more of a need than a want. The Power Stop z36 kit is next on my list since I do pull a big-ish popup camper in summer.
Gregg Eshelman
Idaho
I have said it too many times....a catch can will benefit any engine with a PCV system. Why put crankcase by products back into the intake system? Why dilute the fresh air and fuel charge in the cylinder with crap?
It wouldn't be a problem if the people who design engines would have the PCV vent into a wet part of the intake. But for some reason they love to dump it in upstream of or just downstream from throttle bodies so it gunks up the throttle body and all inside the intake and the Idle Air Control passage and valve.
The only vehicle I've had with a factory installed PCV oil separator was a 1994 Oldsmobile Acheiva with SOHC 4 cylinder. It drained back to the crankcase but the open cell piece of plastic that looked like a scrubber pad would quickly get overwhelmed and it let lots of blowby oil vapor go to the intake.
Orlando, Florida
Thanks for all the great information!
I just placed an order for a J&L (JLT) Oil Separator 3.0 for our 2016 with 103k miles. I’m not really a car guy, but the installation looks pretty simple. I actually just replaced the plugs and coils over the weekend. So I’m learning.
My question now is, should I put a weep hole in the intercooler?
Super Moderator
Super Moderator
No, not unless you are having issues. Any symptoms or weird behavior?
Timo2824
Wichita
I've put one in everyone of my Ecoboosts, you'd be surprised what drains out of it some days! I've not done a catch can or had issues with carbon buildup, but I run mine hard and tow regularly. If you do the weep hole expect an occasional spot on your garage floor. Usually only happens if you run it hard right before parking. If you drive normally for a bit after then it doesn't leave any spots.
Orlando, Florida
Loki,
Thanks for the reply. No symptoms that I can tell. Again, I’m not really a car guy. But pretty much since we purchased it new, we occasionally get some water vapor looking exhaust, especially when aggressively accelerating. My thought was that it was condensation or oil from the turbo. I was hoping a weep hole might eliminate this. Any thoughts?
