So I picked up another Expedition. 99 4.6 AWD.
I replaced the front diff (was blown)
Replaced Spark Plugs.
Replaced a Coil Pack.
Replaced an o2 sensor.
Replaced a the Camshaft Pos Sensor.
The passenger manifold has been replaced. The drivers side has a HUGE rotted hole in the manifold.
The mechanic was supposed to replace BOTH of them with my Pace Setter Shorty Headers but decided he didn't want to do that and just replaced one side with a stock header and didn't do the other at all.
It hard starts, like SUPER HARD. It bounces around at idle, between 500 and 1500. Sometimes it will turn right over, other times its SUPER hard to start. It has back fired both through the intake AND in the exhaust.
When driving it, thankfully only to get it towed away from scum bag mechanic, it won't get up above 55 MPH, has NO POWER driving uphill (I couldn't even drive it on to the tow truck) and drags gears out REEAAALLLLLYYYYY long. I jam it to the floor and nothing happens. Its also throwing lean codes.
When I put it in gear to move it, RPM's drop SUPER LOW and it fights to stay running or stalls. Same thing if I come to a stop.
Would the drivers side leaking manifold cause these huge problems? What else should I be looking for?
