Puddle lights are 31mm festoon type and the cargo light is a 578Ok so can anyone tell me which festoon bulbs these are? My lenses separated easily so I am merely replacing the bulbs and recementing the lenses. I also need to know what size festoon bulb is in the cargo area.
That looks good. I'm really happy with mine. At night it floods the ground with light.View attachment 22699 View attachment 22700 View attachment 22701 finally got these installed from DAYTIME Brightlites. Worth every penny.
You'll get better results replacing the entire unit with the DAYTIME Brightlites. You will not find anything that you can retrofit that is that bright.Ok so can anyone tell me which festoon bulbs these are? My lenses separated easily so I am merely replacing the bulbs and recementing the lenses. I also need to know what size festoon bulb is in the cargo area.
They only come on when you unlock the door or open the door and the idea is to light up the area around the truck. That way it keeps away bad guys because they don't want more light. I think they would fine on your truck but you might like them too much and want to start changing everything over to LEDs.I’ve been going back and forth on putting these in. Were they just pop out and throw the new ones in? Molded connectors? My worry is since my truck is all halogen that it would look too white when my headlights and interiors come on when i unlock it. Maybe if i switched to whiter interior lights it would blend in better. Nice rig your running there, i do like the rims.
Im pretty sure based on the name the idea is to help you avoid stepping into puddles mud n dogshit when curb parking ...
Took me all of 5 minutes to install. Flat head screwdriver to depress the tab on OEM and gently pry outward on housing, DC the two connections, pop the new one back in. Here’s what the connectors on the new ones look likeI’ve been going back and forth on putting these in. Were they just pop out and throw the new ones in? Molded connectors? My worry is since my truck is all halogen that it would look too white when my headlights and interiors come on when i unlock it. Maybe if i switched to whiter interior lights it would blend in better. Nice rig your running there, i do like the rims.
