03' rear A/C question
af mezkin
italy
Hello all,
Here is my question for a/c experts; recently I have noticed that the air coming out of my rear vents is not as cold as the air coming from the front vents (more like cool instead of cold). I have the front and rear a/c in my Expy, I had the a/c serviced with new fresh Freon two years ago right before I PCS’d to Italy. Has anyone else experienced this from their rear air? Is there Freon required to be check at the rear or does it use the same Freon for the front and rear a/c?
Thanks in advance
AF
Hampton, VA
i changed the radiator fluid in my wife's car and it corrected the cool vs cold prob...we're suppose to change it every 2 yrs...unless youhave some other type/brand that says you can go longer...worth a shot
A
af mezkin
italy
I changed my radiator fluid 2 years ago, I went back with what came out (the extended life fluid). I'll check around to see if tf can be flushed out and replaced. Not sure if they use the same fluid here in Europe.
Thanks for the input
AF
