Hi, fairly new to the forum. Ever since I replaced the fuel pump on my 07 expy limited, I am unable to refuel. Gas station pump constantly shuts off at less than 1 gallon. Intermittent filling takes approximately 45 minutes for half tank of refueling. Here's what I've done so far.
1.removed filler neck and blew out lines with compressed air.
2.checked and tested purge valve.
3.removed and had vapor canister tested.( no pellets found as other threads have indicated)
4. Dropped fuel tank and blew out all lines. Also removed, checked and reinstalled fuel pump.
5. Installed new OEM ford fuel cap.
6. Stuck screwdriver in fuel tank bung to attempt any dislodged of possibly stuck anti siphon valve. Still unable to refuel. Any suggestions?
