There are screws, 6 to be exact, and a clip behind tweeter sail panel.
1. Remove the door handle screw cover. (little black square thing behind chrome door handle)
2. Remove the door handle screw.
3. Remove the door handle trim bezel. (thing around door handle)
4. Remove the front door trim panel finish cover. (black rectangle thing down inside armrest pull )
5. Remove the 2 door trim panel armrest screws.
6. Remove the door trim panel screw. (on side of door panel)
7. Remove the 2 lower door trim panel screws.(bottom of door)
8. Disengage the sail panel clip. (behind tweeter- just pull straight out)
Then lift the door trim panel by pulling directly upward on the armrest to
disengage the panel clips.
Matt
