You could also look at this as an opportunity to change the gear ratios to give the truck some more pep. A jump to 4.11 to 4.30 ish gears would make the truck run and shift more like it did when the stock size rubber was on it.
Mine had 3.73 gears in it stock and I was going to bump up to 4.56, running 35 inch rubber.
