rockinrolla
Hello everyone I'm a newbie. I have a 1998 navigator i just got recently and cannot get 4x4 low to work it has the selector dial options for 2wd,a4wd,4hi,4low. The A4wd and 4 high work fine can hear relays clicking and motor engaging 4 hi. I've tried stop depress brake and put in neutral and switching to 4 low nothing no clicking or motor sound I've checked all the wiring to the shift motor and check for corrosion nothing.The actuator is working all the fuses are good. I pulled the shift motor and manually put it in 4low with pliers and it works so it's not the transfer case.I watched the motor off the transfer case while someone else put it in low range and the motor did not spin any thoughts? thank you. Also the low range dash light has never come on even when i first start the truck
