1999 Ford Expedition Eddie Bauer Parts Vehicle
juan214
Stoughton, MA.
1999 Ford Expedition Eddie Bauer Parts Vehicle Best Offer - $4,000 (Stoughton)​
1999 Ford Expedition Eddie Bauer Parts Vehicle for sale. Tons of mechanical parts replaced through the years especially last year. Most documents still available. Truck was Oreo cookied. It was the creme filling, so frame and body are bent and not worth the repair cost. Parts are worth more than the truck. Truck is preferably being sold as whole, but some parts may be considered for part out. Tires are not avaiable nor the wheels (bring a set). If you have a First Generation Expedition your restoring or need parts for here they are. You do not need to go to a salvage and hope you find what youre looking for. If it broke it got taken care of. Does not start, pretty sure it's the flexplate (I have a spare). May have cracked. broke in a perfect circle or the bolts sheared off from the crank shaft. It cranks and sometimes catches just not enough. The motor is not seize it can be cranked by hand. Leave a message.
List of Parts:
5.4L Engine (Complete at the time of posting)
Engine - Rebuilt (Marshals Machine ME.)
Oil& Filter - Ford SYN 5w-30 & Ford filter(8/21 less 1k)
K&N Air Filter
HE Coils w/ S/S Hardware
Motorcraft sparkplugs
Bosch Flow Matched 4 Hole Fuel Injectors
Stainles Steel exhaust manifold studs S/S
Alternator - Reman
Power Steering Pump - Reman
Air Compressor - Reman
Radiator - Replace with new
Pulleys - Replaced with new
Transmission (Complete)
Transmision - Rebuilt (Fuild & Filter 8/21 less 1k)
Transfer Case
Transfer Case - Needs Rebuild (chain has slack) was my next project.
Front Drive:
Front Differential - Drained & Filled (8/21 less 1k)
Front Half Shafts - Reman Both (Detroit Axle) still have originals.
Front Hub Assemblie - New when Replaced (MOOG)
Steering and Suspension:
Pitman Arm - New (9/21 less 1k) (Detroit Axle)
Idler Arm - New (9/21 less 1k) (Detroit Axle)
Inner Ties - New when Replaced (Detroit Axle)
Outer Ties - New when Replaced (Detroit Axle)
Upper Control Arms w/ Ball Joints - New when Replaced (Detroit Axle)
Lower Ball Joints - New when Replaced (Detroit Axle)
Front Brake Dust Sheilds - New when Replaced (8/21 less 1k) one was rotted
Front Brake Rotors - Used not warped inspected yearly
Front Drive Shaft Ujoints - New (8/21 less 1k)
Steering Shaft - New (8/21 less 1k)
Parking Brakes:
Passed inspection (1/23)
Front Brake Cable - New when Replaced (7/21 less 1k)
Left Brake Cable - New when Replaced (2019 less 1k)
Right Brake Cable - New when Replaced (2019 less 1k)
Parking Brakes - Fully inspected and serviced (7/21 less 1k)
Rear Brakes:
Rear Brakes - Fully inspected and serviced (7/21 less 1k)
Rear Brake Rotors - New when Replaced (7/21 less 1k)
Rear Brake Dust Sheilds - Replaced (7/21 less 1k) both were rotted
Rear Differential:
Rear Differential - Drained & Filled (7/21 less 1k)
Rear Axle Bearings - New (7/21 less 1k)
Rear Axle Seals - New (7/21 less 1k)
Sway Bar Bushings - New (7/21 less 1k)
Trailing Arms -
All four replaced (common Ford rot issue).
Replaced factory U chanel arms with MTC Square Tube Style
Upper Trailing - New when Replaced (2019)
Lower Trailing - New when Replaced (2019)
Exhaust: (at the time of posting)
Stainless Steel Signature Series Muffler (2019)
Three of four CATs remain
Tires:
Goodyear Wrangler ATS P265/70R17 (2X in 9/21, 2X in 2018)
Wheels:
17 Inch Ford Factory 5 Lug / 5 Tear Wheels (Four)
Spare: Full size on steel wheel
Body Blue: (Complete at the time of posting)
Right 1st Gen Heated Signal Mirrors - Used
King Ranch Headlights - Used
Halo Ring Projector Fog Lights - New
Glass - All Intact
Interior EB Tan: (Complete at the time of posting)
Air Cabin Filter Mod
Add-on Remote Starter (using factory remotes)
Vector MAXX SST 400W POWER INVERTER (2 custom outlets)
sharprd65
