TSB 23-2351 - 2022-2023 Expedition/Navigator Auto Trans - Harsh-Delayed Engagement And-Or Harsh-Delayed Shift - Main Control Break-In Capable Vehicles
HazBeen
Great Lakes
*** Edited to remove parts lists due to Forum word-count limitations ***
*** See attached PDF file for full information ***
TECHNICAL SERVICE BULLETIN 23-2351
10R80/10R80 MHT Automatic Transmission - Harsh/Delayed Engagement And/Or Harsh/Delayed Shift - Main Control Break-In Capable Vehicles
November 14, 2023​
Model:
Ford
Transmission/Transaxle: 10R80
2020-2023 ExplorerTransmission/Transaxle: 10R80
Transmission/Transaxle: 10R80 MHT
2021-2023 F-150Transmission/Transaxle: 10R80
2022-2023 MustangTransmission/Transaxle: 10R80
2020-2023 TransitTransmission/Transaxle: 10R80
Lincoln
2020-2023 Aviator
2022-2023 NavigatorTransmission/Transaxle: 10R80
Issue: Some 2021-2023 F-150, 2022-2023 Expedition/Navigator, 2022-2023 Mustang, 2020-2023 Transit, 2020-2023 Explorer/Aviator vehicles equipped with a 10R80/10R80MHT transmission may exhibit a harsh/delayed engagement and/or harsh/delayed shift, an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTC) P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the powertrain control module (PCM) or transmission control module (TCM). This may be due to the software in the powertrain control module (PCM) or transmission control module (TCM), the transmission solenoid ID strategy, sticking valves in the main control valve body and/or axial movement of the CDF clutch cylinder (7H351) sleeve. To correct the condition, follow the Service Procedure to identify and correct the condition.
NOTE: This article is for information only. Determine the causal part number and use available labor times in Section 7 of the Service Labor Time Standards (SLTS) Manual or claim M-time in accordance with the Warranty and Policy Manual. Causal part number IN in this article refers to the information only status and is not able to be claimed.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicles:
- 2021-2023 F-150
- 2022-2023 Expedition/Navigator/Mustang
- 2020-2023 Explorer/Aviator/Transit
• One of the following transmissions:
- 10R80
- 10R80 MHT
• At least one of the following conditions:
- DTC P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7
- Harsh engagement
- Delayed engagement
- Harsh shift
- Delayed shift
Warranty Status: Information Only.
Repair/Claim Coding
Causal Part:IN
Condition Code:42
Service Procedure
PCM/TCM Software
1.
Using the latest software level of the appropriate Ford diagnostic scan tool, check for later PCM/TCM software version.
2. Is a later software version available?
(1). Yes - reprogram the PCM/TCM to the latest software. Perform the adaptive learning drive cycle. Refer to Workshop Manual (WSM), Section 307-01.
(2). No - proceed to Step 4.
3. Does the vehicle still exhibit the condition after reprogramming the TCM/PCM and performing the adaptive learning drive cycle?
(1). Yes - proceed to Step 4.
(2). No - repair is complete.
NOTE: Advise the customer that this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
4. Are any of the following DTCs present: P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7?
(1). Yes - proceed to Sticking Valves – Main Control Valve Body, Step 2.
(2). No, vehicles built on or before 1-Nov-2021 - proceed to Transmission Solenoid Strategy, Step 1.
(3). No, vehicles built after 1-Nov-2021 - proceed to Sticky Valves - Main Control Valve Body, Step 1.
1. Reprogram the transmission strategy download into the PCM/TCM. Refer to WSM, Section 307-01.
NOTE: When prompted, select Transmission Replacement (Full Assembly) only and re-enter the production transmission serial information on the side of the transmission.
2. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
3. Does the vehicle still exhibit the condition after performing the adaptive learning drive?
(1). Yes - proceed to Sticking Valves – Main Control Valve Body, Step 1.
Sticking Valves - Main Control Valve Body
1. Determine the appropriate clutch(s) to be cycled related to the symptoms present. Refer to WSM, Section 307-01. Proceed to Step 3.
2. Determine the appropriate clutch(s) to be cycled related to DTCs present. Refer to WSM, Section 307-01.
3. Record and clear all DTCs present before performing the PCM – Transmission Accelerated Main Control Break In routine.
CAUTION: Failure to use a frame engaging lift could damage the vehicle.
4. Prepare vehicle for the PCM - Transmission Accelerated Main Control Break In routine by positioning on a frame-engaging lift with wheels off the ground to prevent vehicle movement.
5. Using the Ford Diagnosis and Repair System (FDRS), perform the PCM - Transmission Accelerated Main Control Break In routine 3 times on the appropriate clutch(s) determined to be cycled.
6. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
7. Does the vehicle still exhibit the condition after performing the PCM - Transmission Accelerated Main Control Break In routine and adaptive learning drive cycle?
(1). Yes - proceed to Step 8.
8. Overhaul (clean and inspect) the main control valve body and road test vehicle following the adaptive learning drive cycle. Refer to WSM, Section 307-01.
9. Does the vehicle still exhibit the condition after overhauling the main control valve body and performing an adaptive learning drive cycle?
(1). Yes, vehicles built on or before 15-Aug-2022 - proceed to CDF Clutch Cylinder Replacement, Step 1.
(2). Yes, vehicles built on or after 16-Aug-2022 - this TSB is complete. Refer to WSM, Section 307-01 for normal diagnostics.
(3). No - repair is complete.
NOTE: For Mexico, U.S. and Canadian vehicles less than 3 years old and has less than 36,000 miles the dealer has the option to continue with this TSB repair or replace the transmission under the low time in service (LTIS) policy.
1. Remove the transmission and mount the transmission to the bench. Refer to WSM, Section 307-01.
2. Disassemble the transmission. Perform only the necessary steps to remove the clutch and planetary assembly from the transmission case. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the torque converter or the hybrid drive unit, transmission fluid pan and gasket, transmission fluid auxiliary pump (if equipped), fluid filter and main control valve body assembly, all 4 speed sensors (intermediate speed sensor A [ISSA], intermediate speed sensor B [ISSB], turbine shaft speed [TSS] and output shaft speed [OSS]), transmission fluid pump, front support assembly and the clutch and planetary assembly. Refer to WSM, Section 307-01.
3. Disassemble the clutch and planetary assembly. Perform only the necessary steps to remove the CDF clutch cylinder and the No. 3 sun gear shaft and No. 2 ring gear assembly from the clutch and planetary assembly. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the A clutch assembly, the selective shim and T3 thrust bearing, remove and discard the 5-input shaft front seals.
(2). Remove the No. 1 planetary carrier snap ring, clutch, and planetary container cylinder, the E clutch and input shaft assembly, the No. 3 planetary carrier and No. 3 sun gear, the No. 3 sun gear shaft and No. 2 ring gear assembly. Refer to WSM, Section 307-01.
4. Remove and discard the sun gear No. 3 shaft seals. Install the 4 new sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
5. Disassemble the C, D and F clutch assemblies from the CDF cylinder. Discard the CDF cylinder. Refer to WSM, Section 307-01.
6. Assemble the C, D and F clutch assemblies into the new CDF clutch cylinder. Refer to WSM, Section 307-01.
7. Perform the C, D and F clutch pack endplay measurements for proper clearance. Refer to WSM, Section 307-01.
8. Remove and discard the input shaft-to-sun gear No. 3 shaft seals. Install the 5 new input shaft-to-sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
9. Remove and discard the input shaft seal. Install the new input shaft seal. Refer to WSM, Section 307-01.
10. Install the 5 new input shaft front seals. Refer to WSM, Section 307-01.
11. To reassemble the clutch and planetary assembly, reverse the disassembly procedure. Refer to WSM, Section 307-01.
12. Perform the T3 thrust bearing measurement to set transmission front end clearance. Refer to WSM, Section 307-01.
13. Reassemble the transmission. Refer to WSM, Section 307-01.
14. Install the transmission. Refer to WSM, Section 307-01.
15. Perform an adaptive learning drive cycle. Refer to WSM, Section 307-01.
© 2023 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
  • TSB 23-2351 - 10R80-10R80 MHT Automatic Transmission - Harsh-Delayed Engagement And-Or Harsh-D...pdf
veedub
On the plains
My 2020 Expy has been shifting hard for several months. Dealership says it will take a month just to diagnose the issue. Where should I take the vehicle to have the PCM/TCM software? Would this be covered under the regular warranty (purchased 5/20)?
KFordEx8
SF Bay Area
Dealer performs the items in the TSB. Covered under base warranty.
The TSB outlines the steps involved.
In a nutshell, dealer does first step with is the software update. If that does not fix the issue, they do step two which is rebuild the valve body. Then step three of dropping the tranny and replacing the CDF drum if valve body fix didn’t work. Between the steps, they’ll give you the vehicle back because it has to go through adaptive relearning.
Full details in the TSB.
veedub
On the plains
Dealership is saying they can’t replicate the hard shifting issue, which is super frustrating because it literally happens every time the vehicle is put into reverse or around 35-40 mph shifting gears. They are saying they won’t perform the flash because it could cause more harm. Tearing out my hair.
tifanydire
