garyankrom
I've got a 2000 expedition 5.4 w/4R100.
mode switch on the dash is A4WD/4x4HI/4x4LO
And no vacuum actuater on the front diff, just vent tube.
tires are all within 1/4 of each other, all at same air pressure.
mode switch is good, lights all work in the dash when respective
4x modes are selected. nothing flashes or is illuminated when it's
not supposed to be.
before pulling codes from the gem I replaced complete front suspension
And steering, cv shafts, hub assemblies with new abs sensors, front and rear
u-joints, covered front diff 4" to keep front shaft in correct plane after lift kit
and serviced front and rear diffs. also before anybody goes there it was doing
this before the lift.
STILL BINDING FRONT DIFF IN TURNS AND HAS LOW SPEED AXLE WIND UP.
pulled a c1107 and p1823 code from the gem.
replaced: gem, abs module, speed sensor on rear diff. pulled 30amp 104 fuse,
Did Brown wire mod.
STILL BINDING TURNS!!!
I need help. I would prefer not to take it to the dealer. any help would be appreciated.
in the past month it's got new coils, New intake, alternator, battery, injectors,
sct programmer, a pair of magnaflow converters and flowmaster 40 series.
so I'm already into it pretty good.
not supposed to be.
Did Brown wire mod.
