I'm trying to track down a problem on my '05 Ford Expedition EB (with < 30kmi). If I let the truck sit for a few days, the battery will be dead, or very low. In the cold, it's worse (predictably).
The battery checks out ok, the alternator is ok. The dealer replaced the instrument cluster per Canadian TSB 06-8-13. They couldn't give any details, but presumably, something in the cluster was pulling too much current after the vehicle went into sleep mode. They took amperage measurements and declared the problem fixed.
The problem still remains. In fact, after two 30min runs on Sunday, it just arely started today (Tues). It was cold here (approx -10F). The vehicle is fully loaded, so I appreciate there will be some current draw when sitting, but I don't expect it to drain the battery within a week.
So I am starting to look up other TSBs to see if there is anything else related, like 18512, 18390, and 05134. Unforunately, I can't find the full text anywhere.
One of them relates to a slight delay from when I turn the key before the starter begins cranking, which is a problem I have.
It sounds like I've got abnormal current draw.
Any suggestions? Anyone else have this problem?
