2006 XLT 125k Timing Chains
FRD88
Montana
When I purchased my 05 last year I noticed a slight knocking noise coming from the timing chains. I only heard it at idle and it would go away when rpms increased. A very good friend of mine has a shop and I had the guys listen to it before I traveled from Montana to Denver a couple months after I bought it to see if they would change out the timing chains before the trip and they agreed they wouldn't worry until it got worse. It seemed like a good idea to me because most people wouldn't have even noticed the knocking I was hearing so off I went. It made it to Denver no problem then half way through Wyoming on the way home, with my mom in our nice new vehicle that I was so proud of, took a dump and left us stranded. Thank god we were only about 15-20 miles from Casper, because there are parts of Wyoming that are not close to anything. Long story short the plastic timing chain tensioner broke, clogging the oil pump intake, and the engine was toast. Most likely it was a phaser that failed and the plastic tensioner was just the weak point that broke. Just my two cents, but I wouldn't wait long for repairs. I was planning on replacing timing chains after returning from the trip and ended up replacing the whole motor.
Habbibie
Is it Christmas yet?
Chicago
Hell I'd save that $3500, sell the expedition for another $3500 and buy a $7000 "alternative" instead! I don't get how you can justify spending 100% of the vehicle value on a maintenance repair... where's the logic in that?
poppie
Wisconsin
Some reading material from a guy who is more than JUST a parts exchanger like at most Stealership's now day's, (3) LINK'S , Ford 5.4L 3v Triton Engine: DO NOT USE AFTERMARKET PHASERS FROM FREEDOM RACING/OTHERS; THIS IS WHY! , ,...………. AND THIS,Ford 5.4L 3v Engine Knocking Noise: This is Why You Don't Buy Cheap Engine Parts!, , ......…...HOW ABOUT A 5.4 WITH OVER 300,000 MILES, 305,000 Mile Ford 5.4L 3v Triton Engine Brought Back to Life After Melling M360HV Oil Pump Install ,
Plati
I'd get a second opinion.
Mechanic says it needs "blah blah blah".
Skeptical it really needs it, maybe it does .. lot of money.
Buyer beware!
1955moose
Well I didn't want to be a said so like the others, but the Melling pump is good, but you gotta spend the $ on Ford chains and phasers. Habbibie and the others know what they speak. Habbibie in particular has gone through a nightmare worse than yours, and ended up with a used Motor. The biggest problem is the phasers and plastic aftermarket tenshoniers. Go with the Ford or top shelf stuff if you commit to the job. It runs around $850.00 in parts, plus a lot of labor, but it works for at least 200k. The other way, not so much, and you don't want to be fighting with your mechanic 20,000 miles down the road. Better to be asking, how's that teenager doing with her SATs? Is she ready for college?
fordexpylvr
iowa
I had a 07 expy with about 80 k miles. started getting a misfire here and there. coil pack here and there and a plug. ended replacing all plugs and coils. I wasn't waiting on a cam phaser too. with all the problems I had plus the left quarter panel was getting very rusty underneath I traded it off. I had it 8 yrs but I traded it while I could still get something decent out of it last month. now have a 17 with 36k miles and purchased the extended warranty till 100k or 7 more years.my 07 had 84k when I traded it
Habbibie
Chicago
LoL you reminded me of the nightmare, I went back and dug up my original thread about fixing my original motor only for it to blow the bottom end 2 hours later... I dont know what I was thinking back then I spent 5k on motor swap and new timing set... 200% of its total value (bangs head in wall), also a new AC compressor, a jasper transmission, open diff to LSD diff swap, rocker panels, exhaust manifold studs, radiator support.... the list just goes on & on!!!
anyways now after all I've fixed up on it I bet you that i have the most bulletproofed 3v expedition on expeditionforum.com, not counting the idiotic part of spending 4x-5x of the trucks total value
1955moose
Yeah but some day, no time soon, you'll be sitting around with the 5 year old, that's now 15, saying dad, what were you thinking? And you'll say son, it was a different time back in 2018, we did stupid things! It was that president Trump's plan, to make us spend our [emoji383]. Well that's my story, and I'm sticking to it!
As much complaining everyone does the 5.4L 3V is a good engine. The timing set is for sure the weak spot for it. Bottom end on these modular engines is very strong. While I appreciate an old 2 valve the 3 valve fixed a lot of things wrong with it. More power up high with the VCT and a more useable overall power band, improved head gaskets, intake manifold design, etc. The plugs certainly aren’t blowing out of the head like the older ones.......but they may also try to stay in there when you WANT them out lol. Although I must say I found the plug change to be easy. Best way to keep a 3 valve happy is change the oil & filter always and often. While not bulletproof it is a solid platform.
