2014 Expy EL - rear sway bar only or end links too?
larkja
NorCal
Going to install a Hellwig 7688. Wondering if I should go ahead and replace the end links too?
Thanks
Adieu
SoCal
Your end links are guaranteed toast.
You probably ONLY need end links
Kjhawkeye1
River Falls, WI
I replaced the links when I did the rear sway bar with aftermarket Moog. They were significantly heavier than the stock ones that came off.
L
larkja
NorCal
Looking for less sway in the rear. I'm sure the sway bar should be replaced with a thicker unit. End links are cheap. I'll just do everything at once.
Thanks all
ccky
