murray978
File under Beating my head against a wall....
I can't find the passenger compartment fuse box in 2014 Limited. The owners manual states:
The fuse panel is located under the right-hand side of the instrument
panel. To remove the trim panel for access
to the fuse box, pull the panel toward
you and swing it out away from the
side and remove it. To reinstall it, line
up the tabs with the grooves on the
panel, then push it shut.
I can't find a panel that will release. I have seen other sources reference a location in the passenger foot well near the floor.
Anyone have any ideas?
Thank you.
Thank you.
