jeff kushner
The manual says:
but this is NOT correct! The correct low beam is the HB3. I do not know about the high beam but will check when I get the correct LEDs to replace the stock halagon low beams.
ALSO, there is NO 3RD SCREW UNDER THE HEADLIGHT ASSEMBLY AS NOTED IN THE MANUAL! There are 4 plastic locating pins but no 3rd screw. To remove, take out the top two screws, then slowly and carefully work the nacelle back and forth while pulling it towards the front, once you have enough room, tuck your fingers between the front fender on the side and also between the grill and nacelle and work the assembly forward and it will slide out.
Here is the low beam bulb:
Jeff
Jeff
