If you have CCD suspension that is probably the nicest Expedition you can get -- even nicer than the King Ranch IMO. I really like the Brunello leather.
One thing to keep in mind: The "Agate Tuxedo Stripe" design on the seats does not wear well at all. In particular, the driver's side outboard bottom edge gets scuffed up from sliding your rear end against the seat as you exit. Thus, it's very important not to do this as it will quickly ruin the driver's seat bottom cover. I've seen several Platinums with less than 50K miles where the seat bottom leather was a real mess.
I've found that if you rotate yourself to the left, then put your feet on the running boards, stand up, and then step down, it helps to prevent scuffing the leather seat bottom. Same goes for the front passenger seat, so warn your passengers not to slide off the seat when they exit.
