2022 Timberline Light Bars
F
FunkyFuzz1833
Florida
Just installed these today... not fancy but a clean look with some extra light. I am anticipating adding a a lager LED down low and in the center in the future if I can find a user friendly way to mount it.
Looks good. Can you tell the brand, size, and how you mounted them? Any pics of install?
MTB2022
livonia Michigan
bought lights on ebay for about 15.00 each . got a light relay switch wiring kit at menards for about 25.00. I made some small angle bracket to mount them to the plastic grille. I will take some pictures tomorrow.
MTB2022
livonia Michigan
angle brackets home made with stainless fasteners. Switch set from Oreilly's, relay mount home made. power wire runs across the top of firewall to power center positive and negative power studs. wiring from relay runs between air box and apron and out through existing hole to the grille area in front of shutters.
LocoMotive1971
Philadelphia Area
I'm looking to do something like this as well. Two questions, who makes the mounts/lights and have you experienced any issues with airflow putting the lights there?
juicefactory
michigan
I just got 4 11 inch lights bars from M&R Automotive. These lights bars function as DRL amber but can change to white fog lights. Easy to install with the wiring harness that they offer. I highly recommend this option as I was searching for months to find something that functioned and looked great.
Lumberjack
Tennessee
A little more than just a light bar! I’ve also seen a f150 / Raptor in grille setup that pulls two air baffles out and replaces them with Baja design lights
Shakeandbake
Somewhere
I've seen that one.. sold by Speciality Performace. I contacted them and Baja, and they couldn't even give me a measurement of the mount so I can see if the active slats on the raptor is the same on the timberline. I would have been happy to try it out, but they couldn't even be bothered to get a measuring tape out.
