They might last just fine. But then again I'm not a fan of the cam phasers or the three valve and won't even own one. These do seem to have problems with dirty and contaminated oil and clean synthetic oil does seem to help increase their longevity or when you have to replace those components. Now, having said that. If you say an engine lasts 200,000 miles, do you mean it lasts and is untouched with the timing chain cover or valve covers never being off? Or do you mean it had the cam phasers and change replaced at a 120k like so many of these?Interesting but don't forget synthetic gets dirty and contaminated like any other oil. I doubt if any of your vehicles will make it to 200k treated like that.
I have seen tons of engines with poor oil change habits and very long change intervals last 250k miles no problem. I have a 5.4 in an expedition that goes 15000 + oil changes and often with standard conventional oil going 12 to 13 thousand miles and it has 260,000 on it.
Very few engines have actually ever worn out do to old dirty oil.
Engines are severely damaged or wear out due to not enough oil in the crankcase, or from sludge or coked up hard buildup preventing oil flow and mainly return down the holes to get back to the oil pan so it can be picked up by the pickup tube and pump it back through the engine. Also, the pickup tube screens get severely clogged up and blocked with contaminants and sludge.
I have seen engines with oil as black and almost as thick as Road tar that continue to run and run and run for years. The Ford modular engine design does have its limitations due to small passages for the oil to return and to get pumped through. They are not as forgiving with thick sludgy oil but sick dirty oil or leaving oil in for 15,000 + miles between oil changes really doesn't wear out engines.
