98 power seat motor help!
chipete
appleton, WI
First I would like thank you guys in advance for the help and the input. I have a 98 eb 5.4 and i need to replace the front driver's seat motor, but not sure how to do it.i was told i need to replace the frame and the motor a assembly. Or can the motor be installed along?
Sent from my SM-N900V using Tapatalk
Mark Smith
Deer Park, TX
are you sure the motor is fried? mine would not work until I discovered that the ground wire had come loose. reattached and full movement restored.
Mark
chipete
chipete
appleton, WI
Mark
The motor works but gear seems to be destroyed. Moving the seat forward or reverse requires someone to help push
r98exp1
