Hamfisted - I install my gauges while at idle ambient temp 95F , Low side 60-62PSI, High side 210-220PSI, in cabin temp 72F~. I started to hose down (not a mist, more low pressure hosing it down) the front end through the front grill. I did that for about a minute, walk around the window to see my temp gauge, temp did drop after 2 minutes, but also the gauge really dropped
1) Low side 42PSI, High side 150PSI, in cabin temp started dropping to 62F~
2) started to rev up the truck to 1000 rpm for ~1 minute , Low side 38PSI, High side 170PSI, in cabin temp 60F~
3) started to rev up the truck to 1500 rpm for ~1 minute , Low side 30PSI, High side 180PSI, in cabin temp 58F~
These number look a lot better due to the hosing down the front end thru the grill. Not sure if the water caused some pressure expansion and release of internal clogged with temperature change (thermal expansion). By this time I needed to run in for a conf call at 8pm, I will test again tomorrow mid morning once the ambient temps hit 90F or higher.
Hamfisted , check this out . Prior to doing above tests, I noticed the suction line from the condenser to the front expansion valve has a "Y" (front and rear AC units). The Y section going to the rear ac is cold, the section to the front expansion valve is warmer with the front AC on. Not sure why the this .I turned on the rear AC, that section of the suction line started to warm up to match the other Y section. At this time the cabin temps were 72F after 10 minutes of idling the truck with ambient temp 95F , Low side 60-62PSI, High side 210-220PSI. At first I was thinking, there is clogged in the evaporator cause I replaced the Expansion valve already. Bu that did not explain the reason for the suction line temp to increase once I turned on the rear AC. I would of thought the rear ac suction line would get colder. I that point I was confused and moved on to your hose test which I'm glad I did
