AdvanceTraction Issue-2013 Expee-Max
fothco
BC
Very interesting theme : my 2013 Expee Max now has : Advance Traction , check ABS , plus 2 symbols for skidding or swerving car , all showing on screen ... No re-set option on Computer Setup etc . These showed up 3 days ago following changing of brake pads and rotors at 115 K kms // 75 K miles . Plse advise . Is the ABS module suddenly an issue ? fothco
More likely a wheel speed sensor. Have you hooked up w code reader? It will tell you which wheel bearing hub assembly needs to be replaced. Mine did the same, it’s because the wheel speed sensor is sending faulty data due to worn bearing or just a fault so the truck disabled those systems.
F
fothco
BC
Hhmm , wheel bearing issues ? Im off to Ford Dealership for Code Reading , Caliper check , plus AdvanceTraction & ABS Brake dash light warning symbols showing . Thnxs for the reply . Strange situation ... fothco
