Air Suspension Off warning
Miekk
Madison Lake, MN
I'm tired of always pushing the reset button to clear the "Air Suspension Off" statement in the drivers information center. Is there a way to make this stay off?
No, I will not accept "turn it back on" as a viable answer, but thanks. :facepalm:
Hampton, VA
Yes but need to know if u did the conversion
Miekk
Miekk
Madison Lake, MN
Nope. Just don't need the truck changing heights and the compressor running all the time. It still load levels so I'm good.
Hampton, VA
I don't know then...if you done the conversion then I could help cause you will need access to the sensor points and use the springs to fix the prob along with some other steps
sharprd65
