Nayterobertson
Hey guys my 97 expedition 4x4 5.4l a/c has eventually became just a cool breeze. It's not cold like it should be nor is it hot. The rear is the same. I figured it was low on freon so I decided to add a little. When I connected the gauges to my surprise it read the correct pounds. (50psi at 95 degrees temp) <that's according to the can of freon I have. So now I checked if the compression is turning on and it is. I'm not sure what else to check. Freon good. Compressor good. Now what? Thought it could be blend door but when I turn it to hot it indeed gets hot. It just doesn't get cold like its supposed to. Any ideas? It anyone else ran into this problem before. The temp is consistent front and rear.
Thanks for your time.
