Cam upgrade
joezek
psl, FL
I've got a 2008 EL Expedition 4WD. Figured out where a ticking/clunking was coming from. It was a seized roller/rocker. The cam lobe is ruined too.
Since I need to replace the cam, I wanted to see if anyone knows if there's an improved cam that gives more torque or mpg. I locked out the SCT system and installed new chains/tensioners. The truck is used to tow a boat about 99% of each weekend of the year.
The plan is to replace the lifters, rockers and cams.
Joe
mr_dave
MN
Performance cams do exist, however they're not cheap and you would need to get it custom tuned to take advantage of the different cam profile.
joezek
joezek
psl, FL
I did some more reading and talked to a few tuners and cam manufacturers for their input. Competition Cams recommended their 127050 cam grind. It supposedly increases the torque about 25lbs at the low rpm range and HP by +30 above 4900. If I have my SCT tuned a bit locally on a dyno then supposedly there's more room for TQ and HP. Most people I talked to said you can hear the cam profile very slightly through the stock exhaust and definitely know it's been changed with upgraded exhaust. No torque converter needs to be changed, or any valve springs etc. Would be a simple upgrade. The mustang forums guys sometimes refer to this cam as a "Stealth" grind because it's barely noticeable until you step on it.
joezek
joezek
psl, FL
The tuner shops I talked to said to eliminate the cam phasers any time you get a chance. One of them said the numbers are even better at low rpm with it locked out. With the cam phasers working it will extend your top end power curve a few hundred rpm's higher and maybe 10 HP more just above 5300K RPM. For towing and daily driving, I don't care about what the engine might be able to do at that redline RPM, so I much rather not deal with the VCT system and all the possible headaches.
The part I like the most about getting rid of the VCT is that the power curve and torque are higher than stock starting at a lower RPM and stay there throughout the entire RPM range, compared to with the VCT system. With the VCT system there's less power at low RPM and you have to step on it more to get the same HP and TQ at the normal daily driving RPM range. The VCT system looks better on Ford's vehicle specs/advertising because it shows about 10 HP higher.
So basically I think using the Comp cam and having the VCT system removed should give the best low rpm performance for towing.
mr_dave
MN
Interesting. I assumed the opposite, that the phasers helped low RPM torque. I couldn't care less about a few hp above 5k. Lockouts, cams, and a tune suddenly sound a lot more attractive when the time comes.
If you go that route I'd be very interesting in your review.
joezek
joezek
psl, FL
Oh damn, I already installed the Comp cams. Probably swapping the engine next week. The engine is on the stand right now.
mr_dave
MN
