cant keep an alignment
tritonman5.4
brooklyn ny
everytime i get an alignment within 2 weeks my front end is right back outta wack and always pullin towards the right side never the left HELLLLPPPPPPPPPPPPPPP
napew2009
saskatoon, sk
alignment
I don't know what kind of work you've done, but mine was doing the same. after a thousand dollars of work done, it's really starting to drive great. Mine is a 1999 expedition EB 4x4. Here's what I was forced to do after putting new tires on: new shocks all around, steering linkages, all four tie rod ends, pitman arm, control arm?, new brakes all around, new rotors, and wheel hub bearings. I've had it in different shops for 2nd or third advice. Most shops told me everything was tight up front, but this one mom n pop shop narrowed down my problem to wheel hub bearing. just got it done yesterday. Drives great. I know you may be thinking that i should have done all this work before doing the tires, but when i have shops telling me everything's okay, my attention turned to other things. A sound I was hearing was a clunk while turning my wheels and on an incline. Get them checked out, it seemed to be overlooked by most shops.
firefighter407
Same problem here with my 99, ford told me it was caused by the slope in the road.
KWT2000
NINE MILE FALLS
this is a common answer the way to correct is to have the camber on the right side set .25 degrees more negitive then the left this will compensate for the slope in the road
