Cigarette Lighter Question
j2gifted
I have an 07 Limited..
Can anyone tell me what voltage the cigarette lighter outputs? [The actual lighter under the radio and climate controls]
Also, whats the voltage output of the power out light in the backseat on the back of the front center console?
Ive googled and searched and cant find anything.
J
j2gifted
Thanks for the reply @6k-Watts ...are u certain of this tho? I ask because I was told they were a different voltage than the other power outlets
Hampton, VA
ur right...i was thinking outlets...i think those are 5v
Bedrck47
Elizebethtown, PA
as you can see in the attached wiring diagram the cigarette lighter and the power outlets are all powered thru fuses from the main bus which is battery voltage
J
j2gifted
I dont understand what that means
Bedrck47
Elizebethtown, PA
ok read your owners manual
the following was copied from the owners manual
AUXILIARY POWER POINT (12VDC)
Power outlets are designed for accessory plugs only. Do not insert
any other object in the power outlet as this will damage the
outlet and blow the fuse. Do not hang any type of accessory or
accessory bracket from the plug. Improper use of the power
outlet can cause damage not covered by your warranty.
2007 Expedition (exd)
Owners Guide (post-2002-fmt)
USA (fus)
Driver Controls
67
Bedrck47
Elizebethtown, PA
kindly update your signature line with year model and engine information. This can be done in the USER CP section as this information helps others give you replies specific to your expy
Bedrck47
Elizebethtown, PA
what that means is it is powered from the vehicle's 12 volt electrical system
PaulMedik
