Cylinder 1 Misfire. NOT plug,coil,or injector. Help
Discussion in '2nd Gen - 2003 - 2006' started by BrinkExpo, Jan 12, 2018.
  1. BrinkExpo
    BrinkExpo Active Member
    Mar 12, 2017
    Coon Rapids MN
    Hey guys I am getting a misfire on cylinder 1 on my 06 expo with 160k miles. The local Ford service manager and I went for a drive with his computer hooked up to find that it was cylinder 1 because it was not throwing a code.
    It only does it around 3,000RPMS and up. We tried swapping coils and it stayed on cylinder 1. We swapped cylinder 1 plug thinking maybe it was overtightened and porcelain cracked but that didn’t fix it.
    He also did a test on the injectors and they all read the same.
    Now he said to pull the valve cover and check the springs.
    Anything else you guys can think of before diving in to that?
    Thanks in advance.
  2. Hamfisted
    Hamfisted Full Access Members
    338
    47
    Nov 20, 2012
    Ft Lauderdale
    Do a compression test on that entire bank and compare readings.
    Tdh777 likes this.
  3. BrinkExpo
    Mar 12, 2017
    Coon Rapids MN
    He said compression was good
  4. Adieu
    Adieu Full Access Members
    32
    1,455
    206
    Dec 22, 2016
    SoCal
    Just cuz an injector reads normal resistance doesnt say much about its spray pattern afair
    1955moose likes this.
  5. BrinkExpo
    Mar 12, 2017
    Coon Rapids MN
    Right, so do you think it is more likely an injector or valve springs? Just wondering what to do next?
  6. Adieu
    32
    1,455
    206
    Dec 22, 2016
    SoCal
    Well.... An injector costs $35ish. And takes <5 minutes to swap out
    Also, you could even just swap it to a different position and see if the miss follows (if you got the obd reader to detect it)
  7. rexster314
    rexster314 Full Access Members
    343
    36
    Aug 13, 2005
    Texas gulf coast
    My '12 KR had a mystery miss several years ago. Plug, injector, coil were all tested to be ok on cyl. #7. Even replaced them just in case. It would shake like a diesel till the engine warmed up, but still had a miss. Dealer was stumped. One of the dealer's mechanics suggested a pinhole leak in the cylinder head. They removed the head and found rampant corrosion in and around #7 plug hole. We surmised that overnight it would leak down and start up would be really rough. After warmup, engine would settle down with just a slight miss. It was a very slow leak as coolant levels stayed pretty much the same.
    Tdh777 likes this.
  8. 1955moose
    1955moose Full Access Members
    1,937
    185
    Nov 23, 2014
    Like adieu stated pop a new or reman injector in that bank first. Always the easiest and cheapest I was taught in school many moons ago! Come to think of it that pertained to my dates too! But I digress. Usually a failed valve spring, will cause the motor to run on 7 cylinders all the time. 3,000 rpm is a load point of most engines, especially considering our 5.4's start to run out of juice above 5,500 rpm. If you've swapped out the usual culprits on #1 bank, then injector is next logical step. Let us know your findings.
  9. blue oval guy
    blue oval guy Active Member
    26
    Apr 22, 2013
    French Camp, CA
    If ignition components are all 100%, you might consider that bank of injectors. The intermittent misfires we have seen here on econoline vans running the 4.6 motor have been injector related.
  10. Mike Saunders
    Mike Saunders New Member
    68
    Jan 13, 2018
    Gettysburg
    I had a 2003 with the 5.4 and a similar problem. Dealer ended up replacing the harness for the #1 plug and that fixed it.
    Drae likes this.
Share This Page
